2002 Grand Prix GT transmisson problem
INDIANANORM
I have a 2002 Gt that has a transmission problem. Has 98000 miles. 3.8 v6. When the engine is hot the transmission shifts hard. when the engine is cold it shifts normal. I have had to fluid and filter changed right after this started and did not help.
Oct 30, 2007 at 5:03 AM
BMRFIXIT
  • 19,053 POSTS
[quote:cec79aed91="indiananorm"]I have a 2002 Gt that has a transmission problem. Has 98000 miles. 3.8 v6. When the engine is hot the transmission shifts hard. when the engine is cold it shifts normal. I have had to fluid and filter changed right after this started and did not help.[/quote:cec79aed91]
Did you try flushing the cooler?
And fill with fresh ATF
Did your problem start after tranny filter and fluid change
U may have the wrong fluid in
Good luck
Oct 30, 2007 at 11:58 AM
