The traction control system will generate a "C" chassis code, sometimes a "B" body code.
Have codes read at trusted garage to isolate problem.
A traction control system will reduce engine power if wheel slippage is detected, if malfunctioning it will cause symptoms you describe.
While most autoparts stores will read codes for free, they can only read "P" powertrain codes.
SPONSORED LINKS
Thursday, January 28th, 2010 AT 8:35 AM
