2001 Pontiac Grand Prix REAR BRAKE LIGHTS
TRACE STRAIN
Brakes problem
2001 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
THE REAR BRAKE LAMPS WILL NOT COME ON IN TAIL LAMPS , ALL THE REST OF THE LAMPS WORK. HAVE CHANGED BULBS , REAR LAMP HARNESS , BRAKE LAMP SWITCH, AND CHECKEK ALL FUSES IN GLOVE BOX FUSE PANEL. THE THIRD BRAKE LAMP WORKS . AM I MISSING A FUSE PANEL SOME WERE?
Nov 3, 2009 at 7:33 AM
MMPRINCE4000
  • 8,548 POSTS
Check fuses in the engine compartment.
You may also have a wiring problem to lamp harness, look for any black soot on the lamp pigtail (socket).
Nov 4, 2009 at 10:33 PM
