2001 Pontiac Grand Prix Loss of power on my GTP
ECOSME74
  • 2001 PONTIAC GRAND PRIX
Engine Performance problem
2001 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
Fixed the MAF Sensor, cleaned the EGR, changed spark plugs and wires. The car runs fine. Problem is when you accelerate to pass another car the motor starts trembling and looses power as if it were choking. I know its not the limiter, there is no exact RPM for the misfire or what ever is happening. When put in a fast acceleration it chokes and trembles, gains power and looses it again in different intervals. If you dont push it hard it runs fine. Has no check engine light on. Im tired of "repairing" different things and the car remains the same. Could it be the ECM, PCM, Supercharger or something else?
Saturday, November 28th, 2009 AT 9:39 PM
MMPRINCE4000
  • 8,548 POSTS
Start by measuring fuel pressure with mechanical gauge. Check the fuel pressure regulator for gas in vacuum line.
Are you getting any boost?
Monday, November 30th, 2009 AT 7:29 AM
ECOSME74
Between the intervals of the misfire you can feel the supercharger boost but then it cuts to the misfire and so on. Ill be checking the fuel pressure this week, thanks.
Monday, November 30th, 2009 AT 7:58 AM
MMPRINCE4000
  • 8,548 POSTS
Let me know what you find. If FP is OK, then you have a ignition problem.
Tuesday, December 1st, 2009 AT 7:57 AM
