2001 Pontiac Grand Prix ignition problem
2001 PONTIAC GRAND PRIX
100,000 MILES • 6 CYL • FWD • AUTOMATIC
JWERK24
  • 16 POSTS
so today i went to work and when i got there i turned my car off, and found i couldnt completely turn the car off its stuck in the last position b4, the car is off. but u can remove the key. and i then turned the ignition and the car started up, with no key in the slot!!!!!!!!, im afraid if i leave the car outside in the area i work in someone will find out they can do it and steal the car:( so any info will be greatful, i think i should replace the ignition and steering colum all together($) but if i can save money someway ill do that
thanks
justin
Jul 19, 2009 at 8:10 AM
MMPRINCE4000
  • 8,548 POSTS
Check with a local locksmith regarding the cost of repairing the lock cylinder and make a set of keys.
I have had several problems with aftermarket replacement key cylinders.
Jul 21, 2009 at 1:51 AM
