2001 Pontiac Grand Prix headlights
BRAIMAH8
Electrical problem
2001 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic
my headlight is on all day but does not turn on at night ,can you please help
Sep 26, 2010 at 9:26 AM
JDL
  • 16,098 POSTS
Are you saying the headlamp switch doesn't work? If so, check the headlamp circuit breaker in the fuse box, check for voltage on the circuit. At the headlamp switch, orange wire is hot all the time. When you turn on the headlamp switch, the yellow wire carries voltage to the dimmer switch.
Sep 27, 2010 at 3:08 AM
BRAIMAH8
the headlights works ,it only goes off sometimes .it usually doesn't work at night ,basically it turns on and goes off on it own
Sep 27, 2010 at 9:36 AM
JDL
  • 16,098 POSTS
All I can do is check the wiring circuits when the problem occurs.
Sep 27, 2010 at 2:20 PM
