2001 Pontiac Grand Prix abs pulsing
73,000 MILES • 6 CYL • 2WD • AUTOMATIC
LARRY R
when i apply brakes they pulsate.i installed new front brakes and rotors didn,t help.
Jul 22, 2009 at 3:24 AM
MMPRINCE4000
  • 8,548 POSTS
If equipped with ABS, they are supposed to pulse, under heavy braking, you may feel it on the pedal.When you replaced the rotors and pads, did it help at all, (few days, few weeks?).If equipped with ABS is your ABS light on?
Try this:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing. Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Mar 16, 2021 at 10:21 AM
