2001 Pontiac Grand Prix ABS light comes on
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
PACERCUB
After you start the car & take off the brake pedal starts vibrating & you hear a grinding noise then the ABS light & the TRAC off light comes on & then stays on. We had a couple of Hub assemblies put on the front drivers side but it still does it. Could it be a sensor or something that is falsely activating the ABS? We've fought this problem for a few years now.Please help!!!
Aug 22, 2009 at 3:08 AM
MMPRINCE4000
  • 8,548 POSTS
Start by having the codes checked, you will need a chassis scanner or a garage that has one.
But if you hear a grinding noise, it is most likely mechanical (rotors, pads, calipers) than electronic.
Aug 22, 2009 at 3:19 AM
