2001 Pontiac Grand Prix Abs??
98,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEY20CAR
Very frustrates with my abs system. abs light is on and trac light is on.
I want to pull the fuse out. Which fuse is it I can pull out in the fuse panel to disable the annoying orange abs light and trac light on the dashboard? what location?
Nov 15, 2008 at 12:46 PM
MMPRINCE4000
  • 8,548 POSTS
Find a garage that has a chassis scanner which will scan the ABS system, it could be as simple as a loose wheel sensor.
I don't want to go worst case scenerio on you, but, if you were to get into an accident (assuming your fault) and the insurance companies found out the ABS was disabled, your insurance may not pay, and the other insurance company could sue etc....etc.
It could get ugly.
ABS and traction control are good things, they prevent accidents and save lives.
Nov 16, 2008 at 12:52 AM
