2000 Pontiac Grand Prix rattle noise from engine when NOT r
2000 PONTIAC GRAND PRIX
147,000 MILES • 6 CYL • FWD • AUTOMATIC
BEEVO
I hear a rattle noise from the engine when I run the comfort system on anything BUT AC or defrost. Does not matter what fan speed I select. Turn on economy and select vents, heater and engine makes tinging/rattle noise. Then when I select AC the noise stops. Fan speed lo or hi makes no difference.
Apr 25, 2010 at 3:38 AM
  • 110,244 POSTS
Check to see if the fan clutch is tight. WHen you turn the AC or defroster on, it engages. When they are off, it is disengaged.
Let me know what you find.
Apr 26, 2010 at 12:37 AM
