2000 Pontiac Grand Prix OBDII read PO300
2000 PONTIAC GRAND PRIX
128,500 MILES • 6 CYL • FWD • AUTOMATIC
JIQUILPENO
  • 6 POSTS
Grand Prix GTP Supercharged read a code of PO300. I put 87 octane will this trigger this code.
Feb 18, 2010 at 2:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P0300: Engine Misfire Detected
87 Octane most likely not the cause of this. Check ignition wires and ignition coil. Check ground wires, MAF sensor, air induction system, fuel pressure, injectors and EGR valve. Faulty oxygen sensors may also cause misfire.
Feb 18, 2010 at 2:40 PM
JIQUILPENO
  • 6 POSTS
Before I had a PO140 & PO171 and I repaired a vacuum leak located on the Fuel Press regulator. Replaced the spark plugs and cleaned out the EGR valve and the MAF sensor. Fuel PSI reads 44psi at idle and 53psi when you accelarate or disconnet the vacuum line on the FPRegulator. Car runs fine, only missfires under boost/load. Codes were erased after these codes with the exception of the O2 senor #2. After these the only code im getting is PO300. I went to the dealer to get it Diagnose and I explained all these to them and they came out with filling it up with 91 Premium octane.
Feb 18, 2010 at 3:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
supercharger may be weakening a bit causing a slight misfire. can you feel the misfire or is it just enough to kick the engine light on?
Feb 18, 2010 at 3:07 PM
JIQUILPENO
  • 6 POSTS
I can feel it under load only, it sputters then it kicks in. But if you drive it regular its all good to go.
Feb 18, 2010 at 3:15 PM
BLUELIGHTNIN6
  • 16,542 POSTS
did you ever replace the ignition wires? what brand and gap on the plugs? spark plug manufacturers and tuners suggest reducing the factory recommended spark plug gaps on supercharged engines because using a too wide gap can result in misfires, loss of power, poor fuel economy, premature spark plug failure, uncontrolled exhaust emissions and possible engine damage. If you use your supercharged street engine for commuting, keep in mind the spark plug gaps progressively erode and widen with everyday use. Did using the higher octane help anything? Did the code come back or misfire occur under load with 91 octane?
Feb 18, 2010 at 4:16 PM
JIQUILPENO
  • 6 POSTS
Spark plug wires were replaced about a year ago and were inspected. they still look new with no signs of heat damaged Spark plug wires AC Delco. Spark Plugs were replaced a couple of days ago when the car had the same syptoms. Replaced with AC Delco Iridium 41-101 Gap to Manuals specs .060
Feb 18, 2010 at 4:38 PM
JIQUILPENO
  • 6 POSTS
I forgot to answer the gas question. No i have not tried it with 91 octane yet I am waiting to get rid of that fuel and I will see what happens.
Feb 18, 2010 at 4:40 PM
