2000 Pontiac Grand Prix MAF sensor
115,000 MILES • 6 CYL • FWD • AUTOMATIC
LANGREN18
How to test a MAF sensor
Oct 17, 2009 at 5:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect for dust or contaminants on the sensor
Using an ohmmeter, measure the resistance between terminals THA and E2. Resistance: At -20 °C (-4 °F) 13.6 - 18.4 KOhm At 20 °C (68 °F) 2.21 - 2.69 KOhm At 60 °C (140 °F) 0.49 - 0.67 KOhm
Inspect the intake air flow meter operation.
Connect the intake air flow meter connector.
Turn the ignition switch to ON.
Using a voltmeter, connect the positive (+) tester probe to terminal VG, and negative (-) tester probe to terminal E2G.
Blow air into the intake air flow meter, and check that the voltage fluctuates.
Oct 18, 2009 at 12:17 PM
