2000 Pontiac Grand Prix Headlight switch
MEDWEST
How much trim or molding do I need to remove to access and replace the headlight /dash dimmer switch? Are special tools required? Do I need to know the location of plastic tabs to keep from breaking them in removal?
Feb 1, 2010 at 12:50 AM
GPGT97
  • 12 POSTS
remove the panel under the steering column first,
then carefully separate panel from around radio,
and ac controls,then tilt wheel down and pull panel
away from gauges.the metal clips will fall off at times,
so a flexible magnet helps retrieve them.
Feb 15, 2010 at 5:54 PM
