2000 Pontiac Grand Prix Head gasket
115,000 MILES • 6 CYL • FWD • AUTOMATIC
BOBM2000
Car over heats quickly, adding water regularly, not leaking on ground. Suspect blown head gasket. Need information on how to repair/replace.
Thank you
Sep 6, 2009 at 1:08 PM
  • 110,248 POSTS
This is an involved process that requires a manual to follow. Here is what I recommend before replacing the gasket. Is coolant getting into the oil (creamy substance on oil cap or dip stick)? Is oil getting into the coolant? Also, have you done a compression test to see if there is a low cylender?
Sep 8, 2009 at 3:39 AM
