2000 Pontiac Grand Prix GTP Supercharger
2000 PONTIAC GRAND PRIX
85,000 MILES • 6 CYL • FWD • AUTOMATIC
BOB BURKHALTER
I have a 2000 GTP with the supercharger. It has about 85,000 miles and the supercharger is making a significant amount of 'rattling" noise like there are bearings about to go out on it. I was told this is not unusual for this supercharger. Is that correct and should I worry about it going out on me? Noise seems to have gotten a little worse in the past few months.
Jul 9, 2009 at 5:19 AM
BRIAN 1
  • 1,030 POSTS
your only option is to remove the S/C belt and run it that way or replace the supercharger. over time the bearing will get louder and there is a possibility it could lock up or break.you could check the oil level and make sure its full,or even change the supercharger oil. Superchargers will make a distinctive "whine", not a rattle. Most likely there is a bad bearing in the supercharger.
Jul 9, 2009 at 11:29 AM
