Many GM cars have a backup oil pressure circuit for the fuel pump, that is, if FP relay goes bad, once oil pressure is above 10psi, the oil pressure circuit will run pump.
Conversley, if OP circuit is bad (low pressure) pump will shut off.
SPONSORED LINKS
Saturday, March 20th, 2021 AT 7:31 PM
