2000 Pontiac Grand Prix Front end noise
142,000 MILES • 6 CYL • FWD • AUTOMATIC
KIRMIE
I am getting a noise from the front driver side of my car. I can hear it from about 20 mph and up. The noise speeds up as the car increases speed but is not dependent on the engine RPM's, pressing the gas, or braking. On fairly tight or banked left turns the noise goes away. There is also a very slight shake in the steering wheel that isn't really noticeable unless you are paying attention. The tires are fairly new as well as the wheel bearing. The car drives great other than the annoying noise.
May 26, 2010 at 9:36 AM
KIRMIE
It is the wheel bearing. My sway bar is also cracked though.
May 26, 2010 at 3:46 PM
