2000 Pontiac Grand Prix fanswitch
2000 PONTIAC GRAND PRIX
160,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVIDEDDIE
  • 6 POSTS
havechecked all relays fuses good fans come on with air on but seem not to be turning very fast car heats up at idle changed temp senser where is fan switch orcould you help me
Apr 29, 2010 at 1:17 PM
HMAC300
  • 48,601 POSTS
there is no switch for the fans. there is the relay and the fuse as well as a sensor to turn it on. Check your radiator for cold spots after it's heated up. If you have any cold spots your rad is probably in need of replacing. As long as it doesn't heat up to the max or red area if you uhave aguage, then it's nothing to worry about.
May 1, 2010 at 12:33 PM
