2000 Pontiac Grand Prix Engine spudders while accelerating
93,000 MILES • 6 CYL • FWD • AUTOMATIC
2000 GRAN PRIX
threw a code says cyc 2 misfire. changed the cyc 2/5 coil pack, check engine light hasnt come on but it still spudders bad under acceleration and around 6-7,000 rpm the check engine light flashes but there are no codes to read so please dont say check for codes.
I saw someone with similar problems but never saw a responce to what fixed it.
Nov 28, 2009 at 7:03 AM
CRZYDRVR
  • 432 POSTS
First thing I would do is test the plug wires. Next was the coil pack new or used? Try to swap a plug wire with another one, as well as the coil pack. If the problem is still showing on those 2 cylinders, then check the wiring harness going from the ECM to the ICM.
Dec 2, 2009 at 7:34 PM
