I had a engine code on my car that was for the coolant temp. to low. So I changed out the thermostat, the coolant temp sensor and the coolant level sensor. Now I have a code that is a 0480 that says my coolant fan relay or wiring is faulty. I changed the relay but the fan still doesn't work.
I had originally had a situation where I was losing about a gallon of coolant every three days. So i put some Barr's leak stop in the motor. That I guess is what ruined my sensors. Any ideas how to fix this?
Feb 26, 2009 at 8:31 AM
