2000 Pontiac Grand Prix cracked spark plugs
2000 PONTIAC GRAND PRIX
RUSSELL350
Engine Mechanical problem
2000 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
Hi- I have a Pontiac Grand prix 2000 with a V6 3.8 engine with 100,000 miles. About 3 months ago,my check engine light came on. I plugged in my code reader and got a code of 301 ( cylinder # 1 misfire). I went to the garage,and the mechanic checked the spark plug,and found it cracked (a split down the side) He changed the plug, and everything was ok for about 2000 miles - then again another 301 code. He again changed the plug and also put on a new set of AC delco plug wires. It was ok until about another 2000 miles - you guessed it - another plug with a hair line split down the side. I am using AC delco 41-101 plugs. This problem is driving me crazy,and nobody can tell me why this is happening. I even spoke to GM mechanics, and they,like all the rest,say they have never ever heard of a problem like this. Also, the car temperature is normal. I sure am hoping you can find an answer to my problem Thank You. Russell.
Jul 16, 2010 at 7:50 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
In my experience, i would say that either floored plugs from the start( rather unusual) or they have been damaged during installation, as others have said, plugs just don't do this, i would try one more, add some anti seize to the thread, and see if it cracks again, i really can't see how this can happen.
mark (mhpautos)
Jul 16, 2010 at 10:45 AM
