2000 Pontiac Grand Prix coolant fan not running
CHARLESR
Engine Cooling problem
2000 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic
tested fans they work,the relay works too,i think its the coolant sensor how do you test it?
Aug 11, 2010 at 9:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
To test an ECT sensor you will need a volt meter. You can test the ECT by back probing the harness while reading the voltage returning to the EEC. Or you can remove the connector completely and test the resistance between the 2 pins on the ECT. The engine temperature must be greater than 50F to pass the KOEO (key on engine off) Self-Test and greater than 180F to pass the KOER (key on engine running) Self-Test.
Aug 11, 2010 at 3:46 PM
