2000 Pontiac Grand Prix car probs bigtime
FANCY
  • 2000 PONTIAC GRAND PRIX
Engine Mechanical problem
2000 Pontiac Grand Prix Engine Size unknown Four Wheel Drive n/a miles
ok our car was leaking antifreeze and hubby bought this gasket kit to replace broken one but once put back to gether hearing a ticking sound and still leaking antifreeze as well as now emmissions light clicks on the dash which I have no idea why, we were looking on the net for torque sequence and cannot find for our car, do you have any suggestions as to what might be going on I am not even car literate so to speak
Sunday, March 9th, 2008 AT 5:31 PM
MASTERTECHTIM
  • 4,750 POSTS
Did he replace the intake gaskets? Did he know that there are 2 different size push rods? Where is the coolant leaking from?
Sunday, March 9th, 2008 AT 5:33 PM
FANCY
  • 6 POSTS
Yes he replaced intake but he says its the rocker arm ticking and no more antifreeze leakage
Sunday, March 9th, 2008 AT 5:38 PM
MASTERTECHTIM
  • 4,750 POSTS
What about the push rods? Most common mistake is not putting push rods back in the right place causing the rocker arms to be loose. Ask him if he is sure they are in the right place. Just trying to help
Sunday, March 9th, 2008 AT 5:47 PM
FANCY
  • 6 POSTS
Just loosened rocker just enough to get rod out and then replace gasket and put rockers back in
Sunday, March 9th, 2008 AT 5:49 PM
MASTERTECHTIM
  • 4,750 POSTS
You had to have all the push rods out at the same time and they are 2 different lengths. YOU MUST HAVE A PUSH ROD INCORRECTLY INSTALLED. Double check and after that triple check. That is the only possible reason for your dilemna
Sunday, March 9th, 2008 AT 6:00 PM
FANCY
  • 6 POSTS
Ok he says he did that and the car sounded good for about 15 minutes later the ticking was there and ty for helping if I forgot to use manners.
Sunday, March 9th, 2008 AT 6:06 PM
MASTERTECHTIM
  • 4,750 POSTS
Ok heres what happened to me one time(i have done this job a hundred times) a nut fell into the intake while I was doing the job and I did not realize until I drove it. The nut got into the engine and blew a hole in the piston and I had to replace the engine. You can start by running engine and disconnect plug wires one a time until you find the problem cylinder and recheck that rocker. The problem cylinder when removing the wire will not change how the engine runs. Good luck
Sunday, March 9th, 2008 AT 6:21 PM
FANCY
  • 6 POSTS
Just pulled valve cover off fire wall side.
First rocker on driver's side back of motor
was loose.
I could move it side to side & up and down, retighten
the rocker nut the noise should go away.
Sunday, March 9th, 2008 AT 6:30 PM
MASTERTECHTIM
  • 4,750 POSTS
Yes tighten all rocker arms equally. What probably happened is the rocker wasnt seated properly at first. Hopefully youll be all set.
Sunday, March 9th, 2008 AT 6:35 PM
FANCY
  • 6 POSTS
Did that car is running good going to take it for a test drive to make sure thankyou ever so much for all your help greatly appreciated
Sunday, March 9th, 2008 AT 7:17 PM
