2000 Pontiac Grand Prix car
214,000 MILES • 6 CYL • FWD • AUTOMATIC
TEXAS4762
im have a bad vibration coming from the front end when im driving but when i let off it stops but when i give it gas it vibrates what could it be?
Feb 7, 2010 at 11:56 AM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
If all is OK, then check fluid level in trans. If OK then have trans checked at trusted trans shop.
Could be as simple as a sticking TCC solenoid (torque convertor clutch).
Feb 12, 2010 at 12:38 AM
