2000 Pontiac Grand Prix AC and Backlight
ADAMLEDET
  • 6 POSTS
Air Conditioning problem
2000 Pontiac Grand Prix Automatic
since buying the Pontiac the backlight on the gauges have never worked, the gauges work and the warning lights still come on. We fixed the problem temporarily by buying a small strip light that plugs into the cig lighter.
Also the AC has duel climate control, for some reason the passengers side blows cold and the drivers is blowing hot, no matter if the setting is on the windshield, face or feet it's always half cold half hot ?
May 4, 2010 at 7:40 AM
MMPRINCE4000
  • 8,548 POSTS
First problem is either bulbs, fuse or dimmer.
Second problem is blend door in heater system.
You will have to remove a portion of dash to fix.
May 5, 2010 at 12:42 AM
