2000 Pontiac Grand Prix ABS LIGHT AND TRAC LIGHT
LONSO
  • 2000 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 13,700 MILES
My ABS and TRAC light off came on today at same time and wont go off. Any ideas?
Friday, September 3rd, 2010 AT 3:02 PM
  • 109,885 POSTS
Both systems work together. Chances are an ABS sensor has come disconnected or the wiring to it has been damaged. You need to have the computer scanned to identify where the problem is coming from. Have that done and let me know what you find.
Tuesday, September 7th, 2010 AT 6:57 AM
LONSO
Joe, I pulled off both front wheels and checked for a problem. The left front hub bearing started coming apart and the three bolts holding it on were loose causing the whole brake assembly to tilt ripping out the ABS wiring. Replaced the bearing and it fixed the problem. Thank you for your time. It worked.
Tuesday, September 7th, 2010 AT 10:25 AM
  • 109,885 POSTS
I'm glad you found the problem. It sounds like you found it just before an accident could have happened?
Let me know if you have other questions or help in the future.
Tuesday, September 7th, 2010 AT 10:09 PM
