Front end shake forty to fifty mile per hour
140,000 MILES • 6 CYL • FWD • AUTOMATIC
I DARCY
Are there any common problems with this drive train, that causes a front end shake while accelerating? I have replaced the sway-bar, struts, and strut-mounts, and had alignment done recently. These things needed done thought it may rectify the shimmy but did not.
Sep 30, 2009 at 11:58 AM
CRZYDRVR
  • 432 POSTS
Could have a broken belt in one of the front tires, or maybe a simple balancing could take care of it.
Oct 4, 2009 at 8:34 PM
SOULDEFECTOR
CV axle(s). On my 2000 GT smooth coasting was acquired after good matching tires and rims on front and different but good matching rear tires and rims were mount, balanced, and installed. Acceleration only wobble disappeared after installation of (I used new) CV axles. A side note my braking also smoothed out and my ABS light went off when I spliced my ABS sensor wire back together. I know this post was 2009 but in my opinion these are still good cars. I hope this helps someone!
May 8, 2018 at 4:24 AM
  • 55,500 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site. :)
Cheers, Ken
May 8, 2018 at 4:56 AM
SOULDEFECTOR
Ken: 2CarPros has provided an unknown amount of reliable information from basic or general to detailed or specific and I and the vehicles I have inquired about have improved with the help of 2CarPros.com. Thank you.
May 8, 2018 at 9:45 PM
HOLTE12
I have a shake in my front end. when I bought it they put a brand new set of four tires on it and balanced and aligned them. what else could possibly causing the shake?
May 9, 2018 at 6:10 AM (Merged)
  • 110,244 POSTS
When do you feel the shake? Are the tires properly balanced? Could you have a bent rim? Have all front end components been checked? Has anyone checked for a bad tire (broken belt)? Also, do you feel the shake more in the floor and seat or more so in the steering wheel?
WRESTLE23
1992 Pontiac Grand Prix six cylinder front wheel drive automatic.
Front end wobble at low speeds shimmy at high speeds.
ERNEST CLARK
  • 1,730 POSTS
That is either a bent rim, worn hub or CV joint.
Check them in that order.
RDWILLIAMS78
I jacked up my front end, and when I shake the tire up and down there is about a quarter inch of play. The lug nuts are tight, and there is not any play when I shake the tire left to right. I was wondering what part I will need to buy to fix this problem.
MMPRINCE4000
  • 8,548 POSTS
Have someone push/pull tire while you look at suspension.
Watch outer tie rod, control arm bushings, ball joint and wheel bearing for any movement.
