2000 Pontiac Grand Prix
145,000 MILES • 6 CYL • FWD • AUTOMATIC
TITLEIST777
My 2000 grand prix doesn't have any heat...if i let it warm for 30 minutes, turn of the heat for 20 seconds and on it is warm for 5 seconds then gets cold. my first guess is the thermostat...but if that isn't the problem...what would it be???
Dec 10, 2009 at 6:36 AM
JDL
  • 16,098 POSTS
Welcome to the forum, do you live in an extremely cold area, if so, you may need to use a block heater. Does the engine ever reach normal operating temp? Do both heater hoses get hot? My next step is to check the directional doors, see if they are operating like they should?
Dec 10, 2009 at 7:35 AM
TITLEIST777
Yes, I live in Minnesota. I replaced the thermostat, and i still have the same problem. It feels like both hoses are getting hot, and my temp is fine. I have good heat if I shut it off for a minute and turn it on high, It works great for 10 seconds then gets cooler and cooler. I'll look into the directional doors... Do you think putting a piece of cardboard in front of my radiator would work??? Thanks for all your help!!!
Dec 11, 2009 at 3:03 AM
JDL
  • 16,098 POSTS
I have blocked off radiator on some of my old trucks, to get the heater to work better. You really need to be careful doing that, don't let the engine overheat!!
If the problem is the directional doors, blocking the radiator won't help.
Dec 11, 2009 at 4:41 AM
TITLEIST777
How do I get into the directional doors?
Dec 18, 2009 at 5:45 AM
JDL
  • 16,098 POSTS
You'll have to get up under the dash.
Dec 18, 2009 at 7:38 AM
