2000 Pontiac Grand Prix
HEAVYCHEVY74
Air Conditioning problem
2000 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
I have a problem with car missing and cutting off when I turn on A/C the engine fans kicks on and engine never run hot ,engine runs at normal temp of 180.Once the car has cool down and restarted I can drive and go anywhere and engine will not miss or cut off as long as I don't turn n A/C
Jun 17, 2010 at 3:44 AM
HMAC300
  • 48,601 POSTS
you might have an alternator problem of not charging enough. Or it coul dbe a battery going bad. Most auto parts can check both but the alternator needs to be off the car. Make sure your battery is chargedb efore getting it tested.
Jun 17, 2010 at 1:23 PM
