I CHANGED SPARK PLUGS, WIRES, FUEL FILTER
NOW I HAVE TROUBLE STRARTING THE CAR
IT WILL START AND RUN GREAT THEN IT WON'T START JUST SPIN OVER
Wednesday, July 22nd, 2009 AT 11:07 AM
JDL
MECHANIC
Hello, did you use the proper oem plugs? Did you install the fuel filter correctly, usually there is an arrow on the filter, shows direction of flow. Use a gage, check fuel pressure. Have a helper crank it, while you check for spark at the plugs.
