how do i remove the hub bearing on the driver side to replace the rotors bolts
Mar 12, 2009 at 10:53 AM
MMPRINCE4000
✓Experienced Mechanic
The hub is bolted to knuckle, USUALLY with Torx bolts. Remove wheel, caliper, brake pads, bracket, rotor, dust shield.
There should be a larger hole in hub to access hub to knuckle bolts.
Be carefull removing the bolts if they are Torx heads, rent, buy an electric impact and MAKE SURE you use the correct torx bit.
