2000 Pontiac Grand Prix
DAVID SOSA
2000 Pontiac Grand Prix Front Wheel Drive
I CHANGED SPARK PLUGS, WIRES, FUEL FILTER
NOW I HAVE TROUBLE STRARTING THE CAR
IT WILL START AND RUN GREAT THEN IT WON'T START JUST SPIN OVER
Jul 22, 2009 at 4:07 AM
JDL
  • 16,098 POSTS
Hello, did you use the proper oem plugs? Did you install the fuel filter correctly, usually there is an arrow on the filter, shows direction of flow. Use a gage, check fuel pressure. Have a helper crank it, while you check for spark at the plugs.
Jul 22, 2009 at 4:16 AM
