1999 Pontiac Grand Prix Trans only works in 2nd gear
140,000 MILES • 6 CYL • FWD • AUTOMATIC
RUNT6869
I can get the car to go starting in 2nd gear and shift it up to drive as I'm going. But I have to put it back into 2nd to start again. Fluid levels are ok. Does it need a filter change?
Jan 9, 2010 at 3:45 AM
MMPRINCE4000
  • 8,548 POSTS
Would not hurt to change fluid, but I would also check the trans linkage to shifter, make sure it is not binding or there is a broken bracket.
Jan 10, 2010 at 12:09 AM
