1999 Pontiac Grand Prix ignition module
216,000 MILES • 6 CYL • FWD • AUTOMATIC
DIESEL71805
I just replaced the tcc solenoid in the car. Put it all back together with no problems. Started the car ran good for about a couple minutes and stalled. Then i had no spark or fuel. Now i've fuel but no spark went over to garage and tried a used ignition module. still no spark. .The tach jumps so that means the crank sensor is working?the only thing i can think of is a new ignition module.Any information will greatly be appreciated
Feb 16, 2010 at 10:59 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coils resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Feb 16, 2010 at 11:01 AM
