1999 Pontiac Grand Prix having a small problem
86,000 MILES • 6 CYL • FWD • AUTOMATIC
JERRYMCDANIEL
yes i just got my car out of the shop i had a motor put in now the motor was bought by us fidelis and i drove my car and it keep dying around turns,stop lights & signs, yeild signs lol and the next day it wouldnt start turns out it was the cranck shaft sensor. Replaced sensor now it still dies around turns stop signs yield signs, my service engin code last read before motor was replaced was mass air flow sensor. Would cleaning it fix my problem or should i go replace it? And in the morings or when it sits for a couple of hours it has a hard tim starting the rpm's jump and then it dies but the rpm's go up and down when idel untell the car dies, but the hard to start could be the air flow sensor or a bad battery?
Oct 8, 2009 at 2:16 AM
MMPRINCE4000
  • 8,548 POSTS
You can buy MAF cleaner at most autoparts stores, try that first. Have battery checked at most autoparts stores for free.
I would also contact installer and let them know your problems, an engine installed under a warranty is supposed to run, not die all the time :) .
Oct 8, 2009 at 2:20 AM
