1999 Pontiac Grand Prix Front wheel wont turn
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
GUYINWA
1 of my front wheels wont turn, there has been a popping sound for over 6 months prior to this problem when i turned the front wheels coming from the front.
What do you think needs replaced to fix it?
Apr 19, 2009 at 1:07 PM
BMRFIXIT
  • 19,053 POSTS
A lot to suspect
1st check brakes (caliper and caliper hose )
2nd check wheel bearing
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 19, 2009 at 1:22 PM
MMPRINCE4000
  • 8,548 POSTS
Also check the CV joint on the problem wheel. If outer boot is ripped and grease is all over the place, the CV joint has failed.
Apr 20, 2009 at 1:09 AM
