1999 Pontiac Grand Prix Front end groan
146,000 MILES • 6 CYL • FWD • AUTOMATIC
058 IRONMAN
  • 6 POSTS
This is pretty simple to explain. It sounds as if I have huge gumbo mudder tires on the steer tires. While I accelerate a low groan grows until it is nearly deafening. When I steer right the sound grows steering left and straight there are no changes what so ever.
Now at a stand still I shift from park to neutral to drive and notice only a soft click from the inside of the car.
Im about to start looking at what the possible cause is but I am in hopes this will all ring a bell with someone.
By the way. The tires are in great shape and symptoms do not change at all if I rotate them. No bulges, uneven wear, cupping or anythng abnormal.
Thanks in advance. Ironman
Mar 8, 2008 at 3:26 AM
MERLIN2021
  • 17,250 POSTS
Check the hub bearings...sounds like one is worn out...
Mar 8, 2008 at 3:34 AM
058 IRONMAN
  • 6 POSTS
I checked the hub bearings once. I can re-check them. I sent you an IM Merlin. Problem gets louder and stronger as I accelerate as well. Iron
Mar 8, 2008 at 3:52 AM
058 IRONMAN
  • 6 POSTS
inner tie rod and wheel bearing slop.
Mar 8, 2008 at 3:59 AM
MERLIN2021
  • 17,250 POSTS
Inner tie rod will sound a bit like a coffee percolator! The groan is the hub bearing...3 bolts and 1 axle nut, and it comes right off...
Mar 8, 2008 at 4:10 AM
058 IRONMAN
  • 6 POSTS
I found both wheel bearings to have slop in there via top and bottom twist. I am getting about 1/4 - 1/2 inch of play from either side.
Mar 8, 2008 at 4:26 AM
058 IRONMAN
  • 6 POSTS
Im thinking I need to unbolt the strut or lower ball joint on this. any input would be appreciated
Mar 8, 2008 at 7:06 AM
058 IRONMAN
  • 6 POSTS
nm... all done.
Mar 8, 2008 at 9:10 AM
