1999 Pontiac Grand Prix Engine wont turn over and start
MOORKEV7302
  • 1999 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 185,000 MILES
What steps do I need to take to find the reasons the engine wont turn over and start?
Monday, February 22nd, 2010 AT 7:12 AM
Pick your symptom: Get back with some results.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Tuesday, February 23rd, 2010 AT 1:46 AM
