1999 Pontiac Grand Prix COOLANT LEVEL LIGHT
288,000 MILES • 6 CYL • FWD • AUTOMATIC
-CAGEORGE
COOLANT LEVEL LIGHT STAYS ON UNTILL ENGINE WARM UP
Apr 4, 2010 at 3:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is coolant level full? if OK then probably faulty coolant level switch/sensor
Apr 4, 2010 at 3:35 PM
SMAX23
  • 12 POSTS
It's the sensor..been there done that..you'll have to drain the radiator down below the sensor level and then change it..you can possible clean it. Mine was gunked up with the orange coolant, which I went to green..don't care what GM says, the orange is not good for your motor. Inside the sensor is a pin..you can clean it, if you don't want to buy a new one. New one is around $45. Good luck :)
Apr 4, 2010 at 6:12 PM
