1999 Pontiac Grand Prix check engine light and change oil l
1999 PONTIAC GRAND PRIX
202,092 MILES • 6 CYL • FWD • AUTOMATIC
SUPER7075
hello i had just changed my harmonic balancer and the engine light still won't turn off .The change oil light won't turn off either ,and i change my oil regularly.do you have to reset the battery or the computer some how and if so how, i dont have an owners manual. Thank-You
Mar 22, 2008 at 5:49 AM
SERVICE WRITER
  • 9,123 POSTS
For the oil light:
Turn the key from off to run position and press the accelerator 3 times within 5 seconds. The oil light should blink and reset.
The check engine light is a different story. this needs to have the codes in the computer read first and then troubleshot based on those codes.
Mar 22, 2008 at 2:27 PM
