The front passenger sway bar on my has broken. I am not in the best spot financially to fix this for a couple weeks anyways- my spouse is out of work right now. Is it ok to drive for the time being until I can afford to fix it- if I take it easy on corners and bumps? It seems to be driving fine, you just notice the break when you go over bumps...
Thanks a lot.
Thanks a lot.
Nov 4, 2009 at 4:39 AM
