1999 Pontiac Grand Prix Brakes and Steering
1999 PONTIAC GRAND PRIX
10,100 MILES • 6 CYL • FWD • AUTOMATIC
CAZZOO 37
My Grand Prix brake sensor is hitting the arm when you turn to the right causing the shield that holds the sensor on to be pushed into the rotor causing a clacking or screeching noise. Only when you turn to the right does this noise happen. It almost sounds like a card in the spokes of a wheel making a tingy noise. Any suggestions to the fix on this. I have tried everything from fixing the shield to bending it away but still no luck. Looking for any suggestions if possible.
Aug 27, 2008 at 11:25 AM
SERVICE WRITER
  • 9,123 POSTS
Get a sheild from the dealer and replace it. You may be able to do some alterations when the rotor is off, but it is possibly rotted, especially if your in the northern states.
Aug 27, 2008 at 11:29 AM
