My ABS light is always on along with low trac light. I was told that if there was an issue with the braking system that the traction control feature would be dissabled. I was also told that both front bearing and hub assemblies needed to be replaced and would solve the issue per computer code readings. I replaced both parts and lights are still on. Also my crusie control quit working so replaced the electronic cruise control box and still does not work. Any help?
Oct 22, 2009 at 12:45 PM
