1998 Pontiac Grand Prix starting vehicle
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
NENASUE
when its cold outside it sometimes takes a while to start up, i was wondeirng if you knew what the problem could be , thank you nena
Feb 17, 2010 at 12:07 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Do you live in an extremely cold region? Do you use a block heater? With an extended crank, I'd have to start with basic checks, spark and fuel pressure. I can't point right at the problem, I'd have to test.
Feb 17, 2010 at 1:05 AM
