Isolate the problem by removing the belts and run the engine for a minute if no noise then check the pump and check the pulley
if you have the same noise after belts was removed then its most likely internal
you should have it check
SPONSORED LINKS
Sunday, May 4th, 2008 AT 7:29 PM
