1998 Pontiac Grand Prix Knocking and sputtering
ARTDASHARK
Engine Performance problem
1998 Pontiac Grand Prix 6 cyl Two Wheel Drive Automatic
I checked the oil and it is good, it has water and everything is fine but when I take off it hesitates to take off and it knocks really loud. It doesn't turn off but it doesn't run like it used to.
Apr 29, 2009 at 1:59 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:6fc608b866="artdashark"]Engine Performance problem
I checked the oil and it is good, it has water and everything is fine but when I take off it hesitates to take off and it knocks really loud. It doesn't turn off but it doesn't run like it used to.[/quote:6fc608b866]
Is it a knock or does it sound more like a rattle or deiseling sound. If it is more like a rattle then I would say that it could be the Timing Belt has jumped timing and need to be replaced.
It could also be the lifters...
Also could be a weak Oil Pump...
First thing to do is to check Timing then Oil Pressure....
Apr 29, 2009 at 2:11 AM
