1998 Pontiac Grand Prix 6 cyl Automatic 126700 miles
everything appears to be in good working order. Cooling fans on - new t-stat - new radiator cap - replaced water pump 1.5 yrs ago - flushed system last summer. Problem: after starting the car and it reaches normal temp, it just keeps getting hotter! The upper & lower hoses feel very tight (i've relieved the pressure and burped it many times). This has been going on for about 3 wks now - after abuot 5-10 minutes of driving, the temp is around 250. A friend suggested that maybe it was a gasket & to use a liquid sealant - I did. Nothing has changed except for now the radiator will not drain at all (which it was draining slowly before). I really really need help with this one. PLEASE!
SPONSORED LINKS
Wednesday, July 28th, 2010 AT 3:54 PM
