The problem occurs only when the temperature outside is above 45 degrees and the car is at operating temperature. There is check engine light its not pulling any codes the computer is reading the sensors tested them pulled sensors just to see if it would pull a trouble code an it did. The problem it surges sometimes really bad sometimes not so bad sometimes it last a couple seconds an does not occur again until i shut the car off an it cools down an starts the process again. but other times it does it constantly an sometimes so bad it starves the engine or sometimes an cuts off. i have been through all the stages an i am stumped can anyone help me
Apr 7, 2009 at 2:12 AM
