Never use the "easy" word :).
Drain engine oil into container, get a magnet and move around in the old oil, if you pick up metal particles, then you have a bearing problem.
If you find metal particles, remove oil pan, rotate each cylinder to BDC and grasp rod cap, if any movement, then rod bearing is bad.
SPONSORED LINKS
Thursday, September 3rd, 2009 AT 7:00 AM
