1998 Pontiac Grand Prix 1998 Pontiac Grand Prix engine nois
1998 PONTIAC GRAND PRIX
108,000 MILES • 6 CYL • FWD • AUTOMATIC
MDRAGER
My grand prix has a knocking sound coming from the engine and i can not figure out what it is. Any suggestions of what it may be? And how much it may cost to fix it?
Aug 7, 2010 at 4:53 AM
MMPRINCE4000
  • 8,548 POSTS
Does knocking increase with engine speed?
Aug 8, 2010 at 1:28 AM
MDRAGER
Yes it does.
Aug 8, 2010 at 3:36 AM
MMPRINCE4000
  • 8,548 POSTS
Generally a knock that increases with engine speed is a bearing (main/rod).
Change oil and drain into container, use a magnet to search for metal particles, if present, then engine will have to be replaced or new bearings, possible crankshaft/camshaft/rods will need to be replaced.
If you find particles, it would be far cheaper to replace engine with used one from junkyard.
Aug 9, 2010 at 12:40 AM
MDRAGER
thank you for the help.
Aug 9, 2010 at 4:31 AM
MMPRINCE4000
  • 8,548 POSTS
Good luck!
Aug 10, 2010 at 1:19 AM
